Sorry if this is in the wrong area.
I have a 2003 1500 4.7L with 117,*** miles on it. Recently the check engine light came on. Sometimes when I just get gas and dont get the cap on tight it will throw the check engine light, but will go off in a day or so after re-tightening. I thought that was the issue, but the engine light has been on for about a week or so.
More recently within the last day and a half, I have noticed a scraping/grinding noise when on the accelerator. The noise is present when the engine is hot and cold. I'm not very mechanically inclined, but tried a few things I knew. I checked the oil and it was low and I was due for an oil change anyway so I went ahead and changed the oil. When I changed it, the amount of oil that came out was about 2 quarts less than what it usually is. I finished the oil change and drove it with it not fixing the problem. Next, thinking it could have been a wheel/bearing issue I put the truck in neutral and revved it up a little bit. The noise was still present.
Honestly, I'm afraid of what it could be. I'm not sure where to go from here. I guess I'll take it somewhere and have the code checked on the engine light. I'm hesitant to drive it to much though.
Any help would be appreciated.
Thanks.
Thanks.
