Scratched Dashboard Plastic
GreenClassic
Las Vegas, NV
2015 Big Horn CC
I have a small scratch (about 2 inches) in the plastic between the 2 glove boxes. It not real deep, but it's definitely noticeable. Anybody got any ideas on how to fix or make less noticeable?
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I will be following to see what if anything can be done
Pneed38
+1 on the follow up...
Sent from my HTC6545LVW using Tapatalk
adurm
FL
2015 RCSB
Dash mat?
Mineralram
i had this exact same problem on my 2013 use a hair dryer or a heat gun and warm up the area slowly and push down very light with your finger or nail.. caution you may burn yourself as the plastic will be warm. As you heat up the area the plastic raised areas that make the area more noticable will begin to shrink and melt back to original shape
Sent from my SM-G930W8 using Tapatalk
Veritas726
This works well however moderate your heat, did this a while back to various portions of the lower dash. When cooled, left the areas a dull finish that no shine kit can restore. Scratches are gone though :)
Mineralram
Opps forgot that part. Work the area and warm slowly not too fast
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
You can use a leather glove to protect your hand and re texture the plastic
gville35
