scuffing/ghosting affect after debadging
Ratket
Arizona-
I debaged my truck last night using the technique in the above sticky section" fishing line , goof off , and the 45*pull angle. worked like a champ. the problem I have now is on my drive door where the "ram" was I have massive ghosting/and a small long scuff mark looks like it is from when they put it on.. the passenger side and the tailgate are all fine it's just this one spot on the drivers side. so what's the best way to try and buff this out? thanks guys for all you're help.
firebuff17
Ct
I had some ghosting and some very minor fine scratches. Used the polish and then 2 coats of wax and it all disappeared.
jhorst
Hampstead
Had the same thing happen to me when I did my car. I used braided fishing line, which was a little more abrasive. Did the same as mentioned in the previous post and that fixed her right up. Key is to pull the fishing line on a slight angle away from the body panels to avoid having it dig into the paint.
powderbrad
Edmonton, AB
I had ghosting, and dust would stick to where the badge was and no where else, even after a good wash. I thought it was weird.
I haven't , however, waxed my truck yet to see if that helps.
kcdt58
Cedar Rapids, IA
Mine had ghosting as well. After a month of having the badges off, it has completely gone away. All I've done was wax the entire truck.
Ratket
Ratket
Arizona-
awsome thanks for all the input, I really appreciate it fellas !!
Jarhead57
Santa Barbara, Ca
2015 4x4 CC Bighorn
I also have the small scuff mark only on the drivers side where ram was, no ghosting though...kinda strange. I have so far not been able to make it totally go away even after a waxing.
2014StormTrooper
Aggieland, TX
2014 Ram 2500 Longhorn 4x4 2003 LY Evo VIII ER Built 2.2L
6.7 CTD / 4G63
one reason i bought a white truck so i wouldnt notice this that much haha
firebuff17
Ct
Use a mild polish. Then wax. The polish will take the scratches away. The wax protects the clear coat. You just used polish to take an extremely thin layer of clear coat off so you need to protect it.
P.s. I am in no way an expert in this field but have read a bunch on detailing. I may have the idea right but may not have explained it 100%
joshhhh
