SD card reader with a 5.0
Wbhvacer
Does anyone know if the sd reader hub can be installed in the place of the aux usb only hub?
SitKneelBend
St. Louis
3.6 Pentastar
Yes, it can, but I don't know if the 5.0 radio can use the SD card reader. The 8.4 radio has the drivers but I don't know if there is a factory equipment 5.0 with card reader so the 5.0 may not have drivers for the reader...
Wbhvacer
Wbhvacer
Thanks for the reply may take a chance and see.
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
The SD card reader with USB hub will not work with a 5.0 radio. Even the USB with the SD reader will not work with 5.0 radios. I have already tried it.
On the other hand, the USB only reader hub will work with the 8.4 radios.
SitKneelBend
St. Louis
3.6 Pentastar
I'm pretty sure the USB is a charge only port.
He's asking about the one in the console, not in the dash. You are correct though, the dash is charge only.
Wbhvacer
Wbhvacer
Hootbro
U.S. Army Veteran
Delaware
Pentastar 3.6L
SitKneelBend
St. Louis
3.6 Pentastar
OK, I read your original post thinking you were talking about the combo SD/USB reader hub that comes standard with RAMS that have the 8.4 radio and not some aftermarket SD reader.
Me too. Now I'm confused...
Wbhvacer
Wbhvacer
I was asking if the factory sd/usb/aux would work in the place of the usb/aux interface .
I know the 5.0 will read sd cards with the use of an adapter from usb to sd
So I wanted to use the factory reader if it would work to clean it up.
I guess I'll find one and test and post the results here.
Thanks to all for your replys
Hootbro
U.S. Army Veteran
Delaware
Pentastar 3.6L
No it will not like I mentioned in my first reply. Been there, done that, it will not work with a 5.0 radio. The 5.0 radio has no provision in the software to recognize a separate SD slot, nor will it read off the USB port either.
Wbhvacer
Wbhvacer
No it will not like I mentioned in my first reply. Been there, done that, it will not work with a 5.0 radio. The 5.0 radio has no provision in the software to recognize a separate SD slot, nor will it read off the USB port either.[/QUOTE
Ok,now that's the information I was looking for some one who had tried thaUSB/SD/AUX INTERFACE. Thanks for clearing that portion up.
when I get back home tomorrow I'll post a video of the 5.0 playing mp3s from the SD to USB adapter I use so if any one wants that option at least they will see it does work. Also it worked with my 3.0 before I switched to the 5.0.
Hootbro
U.S. Army Veteran
Delaware
Pentastar 3.6L
You do not have to post the video unless you want to. I have read of others mentioning using an adapter like you mentioned with the same results. It stands to reason that the separate SD adapter would work since it emulates itself as a USB memory adapter to the factory USB/AUX only port hub.
Express Man
I bought the factory media hub that goes into the console. Bought it when I still had the 3.0 radio, then I went to the 5.0 and now I'm at the 8.4 RA4 radio. Worked great with all three radios. P#68096428AD
