Searching for complete engine harness
Stacy K
Tulsa
Hi. I have been searching for a full engine wiring harness for a 2010 1500 SLT 4.7L 4X4. I’m having zero luck. Are there other harnesses there will fit from different years? Can you make a 4x2 harness work on a 4x4 bc I did find one of those. Thanks.
Brandon-w
Yukon
2015 Ram 1500
The harness for that should not matter weather it's 4 or 2 wheel as the 4x4 part is controlled by another harness form the body control module and transfercase module. You're only looking for the harness for knock sensors injectors coils and mds and other odd sensors?
S
Stacy K
Tulsa
I wish I knew what you were talking about but I don’t. I don’t know much about this stuff but the mechanic we hired can’t find one so they asked me to help. I can ask them. Squirrels ate the wiring so I was told they need a full engine wiring harness. Hearing the 4x2 harness will work helps a lot.
Brandon-w
Yukon
2015 Ram 1500
Ouch that sucks. Yeah I'd ask ur mechanic but as far as it goes with my 2015 ram drive doesn't matter just a generic engine harness. I'll do a part lookup..
Brandon-w
Yukon
2015 Ram 1500
Ok so the harness is supposedly the same. Some 2 and 4 wd Models can take the 775ab harness and others take the 774. Not sure what the difference is but it does say the 4wd will take both ones according to the lookup.
Hope this helps. b5df7575e534cd6a73a64305d405bac5.jpgdf7d3080a1523875c957eb9c9a46c5e9.jpg
Stevieboy96
Ks
odd 2010 is the only year showing that harness.
