Second Alternator Belt Removal (OEM Dual Alternator)
bpgt
Hi,
Just wondering if anyone knows how to remove the belt off of the second Alternator on a 6.4 hemi (2015). The belt is attached to the crank pulley, but it's separate, and in front, of the main accessory belt.
The reason...if anyone is interested in installing a procharger system on their 6.4 hemi, the instructions are for single alternator motors. It doesn't account for the second Alternator with a separate pulley/belt, but it's still attached to the crank pulley.
Thanks in advance!
Tach_tech
5.7L HEMI
The secondary alternator uses a stretch belt, so to take it off you pretty much have to cut it.
B
bpgt
I appreciate the reply.
I did exactly what you recommended shortly after i posted this thread. It was mostly out of sheer frustration, but it appears i was unknowingly heading in the right direction. I have a replacement belt coming.
