Seized or rusted spare tire cable or lift mechanism
RickH
Connecticut
Not that I've ever done it, but make sure that you have inserted the rods correctly, end to end, because if you get them backwards the noise they make sounds alot like what you described. Not that I would know from personal experience!
pscarbor
Many, LA
5.9, 5.7 Hemi, 5.7 Hemi
Thanks for the suggestions! I'm thinking I'm cutting the cable. Mopar replacement is $230. I can do after-market cheaper, but I think I'll bite the bullet and do it right. I will also start with annual lube. Rust isn't so much of a problem here in the desert, but I guess it's worth 20 or 30 minutes of my time. Can't imagine what I would have done if this happened out on the road!
Dorman 925-512, $95 on Amazon. Worked fine for me.
Marshall
Sk, Canada
2014 sport
I wonder if you could spray the hell out of it with a penetrating oil while still up and let it sit for a day two and let the air out and a jack under the rim would be enough to unhook the cable, if the HD are the same as the 1/2ton
Reminds me ,I don't think I tested mine this fall, and temp here just dropped -18c in 4 hours so it will wait for a while .
think the last time I had a tire off was on my 1995 Ram, on the way to Calgary, Ab. with a load on.
Before tire monitors, they are handy things when you get a few years on.
Marshall
Sk, Canada
2014 sport
another thought, take a long wire and poke around in the end where the handle goes, if it's full of rust and dirt, maybe your handle is not hooking up to the winch, why it just spins, air hose may help and a good light to look in there.
Dusty
Rochester, New York
Let some air out of the tire and start kicking it hard to move it back and forth spray the gear box and cable and try again
Kroil Original Penetrating Oil (Drip-8oz Can-Single) | Penetrant for Rusted Bolts, Metal, Hinges, Chains, Moving Parts | Rust, Corrosion Inhibitor (KL081)
https://a.co/d/iErR4PU
Sea Foam Seafoam Extreme Marine & Rv DC-14 Seafoam Deepcreep Aerosol 12 Oz.
https://a.co/d/iBWKHnW
There are a few junk yards in Nevada find a “pick a part” and or call and see if any of them have the spare carrier gear.
I just check ebay inventory and they have an assortment of new and used for under $90
Ziebart drops mine every year because they won't spray around the tire.
On my 2010 the first time I tried to drop the spare, I could see the cable unspooling into a knot, so I just kept pulling downward until I could get the entire cable out. then lube the heck out of it.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 106821 miles.
jonstull829
Scottdale, Pennsylvania
I'm having the problem with my spare on my 2012 1500, the cable drops down but the spare doesn't move!!
I tried everything from kicking it to hitting it with an 8 pound sledge hammer, even prying on it with a crow bar!!
Nothing!!
People have given me advise to try cranking it further clockwise to release it!
Anyone know what's going on with it?
(It looks like there is nothing holding it when the cable drops, it just stays stuck!)
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Nothing!!
WOW so the cable will drop and spare stuck,, Never heard of that,, Maybe spraying WD40 or other type penetrating oil on the rim through the wheel lug holes and ?
I get mine sprayed with KROWN under coating oil . I am also over due for it :O I drop the spare when I head to shop. Hope you get your spare down,, Please update when you do and what you did ! I am sure you are not the only one
Badger 13
North Idaho
2013 Dodge Ram 1500
I'm with "Rado", I have never heard of that. With the holding plate that attaches to the cable is loose, from there is nothing else holding it. Is it possible someone put a hidden locking cable on it ? Maybe try dumping the air out of it, and use a bigger hammer..
Marshall
Sk, Canada
2014 sport
There is no bolt, nut in any of the wheel stud holes? If it’s a used truck
Maybe a anti theft thing?
One of these inspection cameras would help and look at top side of tire.
Bigger hammer?
Marshall
Sk, Canada
2014 sport
I think these winches have a clutch
So you can’t over tighten them
Do you know someone that has a Port-a-Power, ( JK )
That is what the Fire Dept. uses to open jammed car doors
Marshall
Sk, Canada
2014 sport
If you really get at the end of the rope, chain it to a good tree and giver a little jerk.
That’s the redneck coming out.
topherztoyz
