Sensor or component
rw2018Cummins
Central Texas
I have a 2018 ram 2500 and last night the ambient air temp said -33 degrees. I am wondering where this sensor is on my truck. I have searched and some say behind the grill then others say driver mirror. i am going to check about the driver mirror when I get off today but I thought I may have found it last night. There is a sensor or electrical component of some sort that is located on the passenger side. it is under the hood but up on the cowl above the firewall. I thought someone here might know what that sensor is if it is not the ambient air temp. It has a red slide clip on top that slides back to be able to disconnect but I still could not just pull it out easily so I decided to do a little research first.
retired
montana
on my 2020 it is in the driver mirror
R
rw2018Cummins
Central Texas
I am going to check to see what is there on mine after work. If it is there that is good but I am still curious what the other sensor I found is for. I am going to get a picture of it and post on here to see if someone knows what it is.
Thanks for the reply
R
rw2018Cummins
Central Texas
Update it looks like the ambient air sensor is in the driver mirror just like the pic above.
So what is this that I found and was messing with on the passenger side.BD7F4618-9CF6-4FE6-B6A6-4F294B5CB355.jpeg962C144B-0DBE-43CF-A4AB-3409EE3030B0.jpeg
R
rw2018Cummins
Central Texas
So is that little deal in the end if it just a cap to keep dirt out I could not get it to come out.
jimn
