Serv4X4 and Traction Control Light Only on. 2010 Laramie
Steveivor
Canada
My 2010 1500 Laramie, last night the Serv4X4 and Traction Control light came on, the ABS light did not, and there is no code being thrown, anyone else encounter this problem? Truck drives fine, only recent work, just over a month ago I changed the front lower control arms, strut assemblies and the front breaks, I also removed the front end levelling kit the previous owner installed as I do use the truck to haul a loaded horse trailer.
Redfisher1974
Palmerston Ontario Canada
Does cruise control work? If not it’s probably ABS related, possibly you knicked a wire or connector on front speed sensors. Or ABS module connection, also check front axle disconnect connector. There will be a code in TCCM but you need a very good scanner to read it.
DILLIGAF
Canadian Forces
Canada
Scan it with a real scanner
