Jrf07d
A few days ago I started to get a service front sensors error on the display. It would pop up then go away for a day, but now it stays on all the time. The error message says "service front parking sensors". I looked at the front bumper and wiped them all off but the error remains. How can I tell if one of the sensors is bad and needs to be replaced, or if I need to reset the parking system, or remove the sensors and clean them a different a different way?
Jrf07d
Jrf07d
Just an update on the front parking sensors. I went through and looked for a bad fuse and I did find a 20 amp fuse popped so I replaced it and fired up the engine and the warning was still listed as service parking. I went back and the fuse was popped again. I will check again tonight and see if the fuse blows without the engine being on.
Could water have gotten in the sensors and caused a short in the system or do I have a bad sensor that needs to be replaced? I will be checking the wiring this week and see if I can work on narrowing down the cause of the sensors not working, if it is the wiring grounding out some place or an individual sensor of which causing the problem. I am not sure how to remove the front bumper, I will look up in the service manual and see if there is a diagram of removing the plastic bumper to access the sensors and wiring. Will give an update when I have new information.
torontodee
toronto
does the whole front bumper need to be removed to change a sensor? Ive had someone hit my truck and the sensor is now inside the bumper. Any help?
turkeybird56
Central Texas
JFR: U got a short somewhere
brianw0048
EcoDiesel
I have a sensor that goes nuts every time it rains. The front has been turned off for weeks now, got tired of it.
jbrown5030
Sea Level, NC
5.7L
Same. It's driving me nuts with all the rain we've had lately. I never have a problem with the rear though. I was wondering if driving in the rain is forcing water into one of the sensors.
brianw0048
EcoDiesel
mine is exactly the same. not one issue with the rear sensors - only the fronts.
buglao
Memphis, Tn
Same here, When it rain front sensor acting up.
RigRat
Okotoks
Hello, just curious if anyone has had any luck replacing these. I have a bad sensor on my front bumper. Watched a video and looks like a 10 minute job to replace them, and Amazon has the parts for like $35. I have read though some have done this but the warnings seem to stay. Talked with dealer and said when new sensor is installed there needs to be an update? Anyone done that?
Thanks for the help.
Sent from my SM-G973F using Tapatalk
