So rented a small trailer to do some landscape work this weekend. I'm driving turning a corner and hear a fairly loud click click click click in the steering area. It only did it on that corner and is no longer doing it. Loud enough it definitely caught my attention and I was like what the hell was that? All of a sudden my dash lights go wild for a sec and I thought I was going into limp mode. The light next to the traction control light (it looks the same as TC light) pops on and an error message to "service the trailer brake" message comes on. I keep driving for a bit as everything seems fine minus the message and assume its an issue with the rental trailer.
I notice that cruise no longer works. So I pull over and check the wiring to the trailer (seems fine), unplug it and turn the truck off. Fire back up and the message is still there. Check the lights on the trailer, everything still works fine. So I continue doing my landscape work and figure I'll worry about it later. Driving another load of mulch and all of a sudden "service abs system" pop on, I feel my brakes catching a bit as if the abs is kicking on and off. Then about 5 seconds later it goes away and is normal. Continue driving another 20 miles and it never comes back on.
Get home do some reading on here and on the FB group and most common I see is either 1. wiring to trailer needs fixed. 2. The clock spring broke 3. The abs module needs replaced.
I'm really hoping for option 1 or 2 as it appears the abs module is pretty spendy. Due to the loud clicking upon turning that started the entire thing, I'm definitely leaning toward the clock spring. New clock spring is $200. But I don't want to just start replacing crap and then that not be it.
Thoughts? Might disconnect the trailer and the battery for a bit and see what happens.
