Shake in rear end with new A/T tires
Ramdan32
Kansas
i have a 2014 sport 4x4 and I just put new Kanati Trail Hogs on. They are a much heavier tire but still the same size as the stock ones. I have a shake in the rear end at 70 + mph. Have balanced and rebalanced all the tires, switched them around and still have the same problem. Truck has 80k miles so I’d hope it’s not a “U Joint” but could it be the rear shocks just can’t handle the heavier tire?
hodge-xj
5.9 cummins
Were they spin balanced, or road force balanced. They may spin balance just fine but have bad run out of a slight out of round which road force will pick up.
Ramdan32
Ramdan32
Kansas
They were spin balanced twice with no issues.
JB1
Houston, Texas
So based on the thread nothing ever got fixed on that guys truck. He traded it in because they couldn’t figure it out.
yes, but I'm not saying that will be your outcome....just maybe look into that service bulletin after having yours road force balanced.
Use this to locate a shop with the hunter road force balancer
https://www.hunter.com/gsp9700
Ramdan32
Ramdan32
Kansas
Okay thanks for the info. I’m dropping it off at the dealership on Monday to let them figure out what’s the deal
Reactions: JB1
tidefan1967
Summerville, South Carolina
Where were your new tires made? I know a lot of people are looking for great deals on tires with them being so expensive nowadays and China is providing a lot of those great deals. Problem is Chinese quality is not that great. Not to mention bigger heavier tires are going to ride worse than the factory tires and vibes and such are going to be more noticeable. I would also have had those rims checked for straightness without the tires. A slightly bent rim would be much less noticeable with a well made tire and a proper balance than the opposite.
werdna1977
Ontario, Canada
I went through this issue with my cooper stt pros. Regular balance 3 times and issue remained, had my local dealer road force balance them and bow they are corrected.
kkreit01
Olathe, KS
What tidefan1967 said....Saving money by purchasing off-brand Chinese tires is the wrong place to save. Unless it's a 30-yr old farm truck - never driven on a highway, I would only purchase major (name) brand tires.
They do look nice and beefy though.
Ramdan32
Ramdan32
Kansas
Update I had them looked at and they decided the tires were out of round. Getting a new set and will have them in this week! Hope that fixes it. However I cannot express the fantastic customer service I received from Simpletire.com.
JB1
Houston, Texas
You getting the same brand/size etc?
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
On my Ram had a problem like your describing and it turned out that :Caffeine:on one of my wheels I had a clump of dried up mud stuck to the inside of the wheel it was so dried and hard almost like steel cleaned it out and truck road normal after that P>S had to look really good to see it
ChloeBrooks
