shocks upgrade??
blackout514
I have a 2004 quad cab 4x4 hemi and I need shocks. I do haul heavy loads often, and sometimes I tow. I want to upgrade my shocks, maybe rancho or bilstein, but want ones that will be able to do the job, but also still ride better than stock. also, I want to upgrade my sway bar bushings and ends links as well, because Im noticing more roll into turns. so what do you guys think?? thanks.
pajeepman
SE PA
5.9 magnum
I got the monroes with the coil overs and love them. Raised the rear 1.5" and does not sag much at all with my travel trailer (17' 3200gvw). Rides so much better than before, i did have a shock that the lower mounting eye broke off of though.
Sent from my SM-J320P using Tapatalk
hemibaby
BC Canada
2003 Dodge Ram 1500 Quad Cab 4X4 SLT
Get the standard Bilsteins, Got the Bilstein load assist shocks and they're good when i need them, but there is basically no give in the rear suspension when its unloaded.
