Show me 20x 9 wheels with different offset...
SPEEDSTER00
I'm looking at a few different wheels that are 20x9 with 0 and -12 offset. I have a 2014 1500 larime with factory flares running a stock size tire on the chrome 20x9 with +23 offset. I want the wheels even with the flares . The pictures I've found have me confused . Some 0 offset looks wider than -12 and vice versa. Maybe they're so close it doesn't matter?? Help me with some advice here. The truck is leveled so eventually I'll run a 33x12.5 or so.
quietpeen
2021 TRX
Hellcat
I’m pretty sure your stock wheels are not +23 mm offset. The 20x9 wheels have + 19.05mm offset.
If nobody posts pics a good place to look is customoffsets.com. They have a gallery and you can sort by wheel size, offset, and tire size.
SPEEDSTER00
SPEEDSTER00
Thats exactly where Ive looked. Through their gallery Ive seen 0 and -12 that nearly contradict each other.
quietpeen
2021 TRX
Hellcat
I think the widest part of the factory flares stick out about 1.5”. A zero offset wheel will only push out .75” further than your stock wheels if you use the same size tire. The -12mm wheel would stick out 1/2” further yet. Depending on tires you may want the -12mm
Robocop_9
West Virginia
These are 20x9 with 25 offset. They set out even with my flares.
SPEEDSTER00
SPEEDSTER00
Thanks Robocop. That's a -25 correct?
Sent from my SM-G935V using Tapatalk
Iwishforaname
