Shudder in OD
SFD213
So I have a 2004 5.7 with a 545RFE. Trans was rebuilt about 30k miles ago with “upgraded” TC (no idea what “upgrades” means from this guy as I no longer trust him or go to him) with a “shift kit” (again, quotes because who knows if it’s an actual upgrade or snake oil). Now when it shifts into OD (50-60mph) the truck shudders constantly and like crazy to the point where it’ll actually shake the truck and effect steering. Tap the throttle a little harder to come out of OD and it all goes away. WOT and there’s no misfire but the gears do hang a bit after coming off throttle. I did have a CEL for a misfire recently but I changed the two plugs in that cylinder and swapped the coil pack with the other bank incase it happened again and the CEL traveled with the coil pack. No misfire since. Is this a torque converter going bad yet again or even the whole TC and trans? Maybe a misfire that hasn’t thrown a code yet? Could use some help here
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
Only experience I've had with a shudder into O/D was a Nissan. That being said they replaced the tranny under warranty. Didnt think twice about adjusting or repairing, just swapped it out.
Marley
VA
I would do the simple things first.
(1) check fluid level with engine hot and running while in neutral, E-brake engaged on level ground.
(2) make sure mounting bolts on trans and TC are drawn.
The 545RFE consistantly delivers 200k in service miles.....can't imagine it's going out again.
Marley
VA
And it could be an unbalanced tire/ball joint that shows up at 50 mph......lifted vehicles, especially Jeeps are famous for this.
You can Google it.
SFD213
SFD213
Thanks. Going to check it next weekend when I get the time to. Today is wet and crappy and my week is always full.
You can Google it.
My tires could be unbalanced, and I have lifted it and thrown chunkier 33s on, but I the problem would be at that speed regardless of OD or not. When I kick it out of OD and accelerate through that speed in a lower gear the shuddering doesn’t happen. Definite performance loss. Hopefully the checks pan out and reveal low fluid or something
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
If the code followed the coil, then I would replace the coil.
SFD213
SFD213
1) I checked the fluid level when hot in neutral on level ground. Is it possible to be too full to cause this problem? Doesn’t seem WAAAY over but it’s above the hot line.
2) what do you mean by bolts being drawn and where are they located. Do you mean bell housing to engine block or underside or...? And are there exposed bolts relating to the tc outside the trans case or is this inside? If inside then I won’t be able to get to them without dropping the trans
Marley
VA
I'm just trying to figure the shudder your describing in my head.
A friend of mine recently had a shudder and found his transfer case mounting bolts " exposed "were loose.
I do a lot of heavy towing and lost 4 transmissions over time and experienced slipping as they were expiring, never shuddering.
Regarding your Tranny fluid......slightly over is fine and won't cause issues.
I run all my fluids on the high side.
If you sure it's a transmission issue than if it were me, I'd drop the pan, replace the 2 filters, replace gasket and Add ATF 4 transmission fluid.
SFD213
SFD213
Ah TC as in transfer case. I thought you meant torque converter. Yeah I can check them as I’ve had a little work done on it lately but it was happening before that. I could drop the pan and change em out. I’ve been thinking about doing that too. Was reading on forumz that it could be the fuel pump not providing enough pressure too. I could see that also as I haven’t touched that one. Might have that test run on it
SFD213
SFD213
Figured it out. As I was heading up to the trans shop for a diagnosis, the truck threw a code. Checked it and sure enough it was P0307. Misfire in cylinder 7. Replaced the ignition coil and now it’s all good
JohnnyMac
Thanks for getting back and letting us know. Glad you figured it out.
Crapo85
