Side mirror camera install
Jonny Walker
Georhia
Was thinking of installing a front facing blind spot camera on passenger side mirror to help wife with driving/parking when she borrows the truck. Have a ‘15 tradesman 1500 with a RA-2. Does anybody know if the RA-2 has an input for the cargo camera? Or any thoughts on whether or not I can use it for that if it does?
adrianp89
Tampa Bay, FL
I think the PAC CH41 works with the RA2, I would check to make sure though.
R.L.K.
Bristol , Tn.
The RA2 To my knowledge is only capable of one camera ( backup cam ) For multiple cameras you could upgrade to an RA3 or RA4 8.4" Radio .
J
Jonny Walker
Georhia
Thanks guys. I thought that might be the case. I will just go with an extra monitor. That way she can still see the right front corner when backing up.
J
Jonny Walker
Georhia
Ok got camera setup and separate monitor. But need power supply. I’ve seen a lot of posts say you need to set up a new relay and you can’t piggyback off something else when running power. I don’t think the camera or 3 inch monitor pull much at all. Anybody know how sensitive the system is? I was thinking of piggybacking from back of 12v power outlet. Will this not work?
rockyj69
