Single to Dual Exhaust Help
Batman&Robin
5.7L Hemi V8
I am looking to upgrade my Outdoorsman to a dual exhaust and make it louder. Looking to make it growl like a V8 should. What parts, beside a new rear bumper, would I need to purchase?
Thanks!
bassheadhemi
Montreal, Canada
To install the dual factory tail pipe you will also need theses on the driver side
Isolator 52103718AB
Isolator 52103717AB
Hanger 52122572AA
Bolt 06104390AA
Sent from my SM-N950W using Tapatalk
grizzstang
Calgary, Alberta Canada
You could just save yourself time and money and put an aftermarket muffler on it with a hidden tip.
full
Mossybloak
Utah
5.7 Outdoorsman
^ I did the same thing....way cheaper. I ordered a 5" turn down tip from amazon (meant for RV's) and added it to help give it a deep rumble. Can't see any of the exhaust unless you crawl under the bed and look. The dual factory exhaust does look nice though so good luck if you go that route!
MADDOG
Living in a Firepit
On my 3rd gen MegaCan Hemi I removed the stock system from the muffler back and installed a single in/dual out Magnaflow muffler. The exhaust shop bent up two new tail pipes for me.
The sound was great with a nice burble at idle, low rumble at highway speeds and when you got on it the truck got loud and nasty.
abouttobeglue
I wouldnt go factory, I'd get a front side exit exhaust
Ohio5pt7
Ohio
Thanks!
This would be the cheapest route if you like noise xpipe is only like 50
Sent from my SAMSUNG-SM-G891A using Tapatalk
rduchateau2954
I run a si/so carven AR1 - y pipe - no res - 4x16" black tips at 45°
If you're gonna spend the money, why do it to look like 90% of the other rams on the road?
Excuse the messy garage, it was the change of the season.20190418_175100.jpg
sublime2300
