J
jub jub
Guest
It seems with the windows up, the pressure inside the cab makes it difficult to gently close the door. Instead, I have to slam it. It's worse on the drivers door, at least in my mind.
Isn't there a built in pressure relief to help alleviate this? I know on my car, I have windows that drop about an inch until you close the door and then they close. I had another car that had rubber flappers that would vent pressure.
Does anyone know if there are pressure relief vents inside these trucks or do I have to keep being the manly man and slam them shut?
