slight knocking noise on start up
sullivan
Houston, Texas
slight knocking noise on start up, help me out
alll is solved now :)
I cant tell what it is, with the A/c and radio off, I can very faintly hear a knocking noise on start up, and even fainter on turning the ignition off.
When the motor turns on, it almost seems like a vibration is set off and shakes something and something is having a wobbling clunk sound.
Its soo faint. I changed my oil today, and the noise has decreased. Again, I can't tell exactly what it is. Every single fluid has been changed, except the tranny so far.
I hope this is just a small thing... :(
rocket
Licensed Dynacologist
Pennsylvania
was 2006
was a HEMI 5.7
This could be a motor mount, They tend too twist out of whack because of the torque associated with start up/shut down. It may also be something in/near the motor itself. ac lines tend to hit a wobbling motor. Ya gotta realize that at those times, start up/shut down, Thats when the motor will lurch the most. It may be a connecting rod, but that would have more symptoms then what you described here. Good luck Sully, I would inspect for loose anything near the motor, then have a friend start up you truck and see if it /anything moves. Another thing you can do Is put it in gear and put some stress on those motor mounts, You'll know in a hurry if one is broken. Do it in reverse as well. btw.
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
If you suspect an engine accessory as the cause, remove the belt and start the engine.
rocket
Pennsylvania
was 2006
was a HEMI 5.7
Just don't try it with a overhead cam engine!! Can you say Kaboom!!
rocket
Pennsylvania
was 2006
was a HEMI 5.7
You're kidding, right? Are you referring to engine timing? Ram's use chains and not belts.
I'm referring to the r22 toyota motors and other high compression engines that rely on rubber belts for there cam drives. I don't think I mentioned mopar, If I did It was clearly a typo, or misunderstanding.
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
Oh ok. I get what youre saying but I was referring to the accessory drive belt, not anything to do with timing. I'm not trying to be a ballbuster here, but the Toyota R series engines all used chain drives.
sullivan
sullivan
Houston, Texas
This sound has happened before, but its gone away after some recent maintenance and now has come back.
A month ago, I took a 1000 mile trip. When I got there I had this issue. when I drove it sounded like something was knocking in the front right of the truck.
I hope this is just an engine mount...
rocket
Pennsylvania
was 2006
was a HEMI 5.7
Well at the very least you now know how too check for it. good luck sully.
yeah, i'm schooled once again, Thanks ramtech.
sullivan
sullivan
Houston, Texas
Im trying to learn everything I can, I cant stand shops after last year.
They overcharge, don't do things correctly, and fu*k stuff up. Ive had bad experiences.
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
Time to look for a better shop then. Ask around among friends and family and check with the local BBB.
sullivan
sullivan
Houston, Texas
Figured it out guys, its was the freaking cold air intake slapping around in its box. Placed a towel under it for now.
rocket
Pennsylvania
was 2006
was a HEMI 5.7
At least we were close, sorta. I thought it would be something knocking close to the motor. Not something attached, lol. Glad you figured it out.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Tyler see about some weather stripping to go around the collar of the housing to act as a gasket and hold it in place.
sullivan
sullivan
Houston, Texas
Funny that you say that, I just placed some on there last week when I did some maintenance. Guess the damn thing fell off haha
rocket
Pennsylvania
was 2006
was a HEMI 5.7
Did it take another pair of eyes too find the culprit??
Rbeck3
