Soft tonneau lighting
Miami Son
Banned
Port St. Lucie, FL
2012 Ram 1500 Sport Crew Cab
I see this is a popular mod in here so thought I'd share mine. I did this on my 2000 Ram and just had to do it again for the new beast. The install is pretty easy, but time consuming and requires some soldering skills, and electric drill and some hand tools. Total spent for this mod was about $65 for the lights, connectors and wiring supplies. Total time was about 4.5 hours.
These are the LED strip lights I purchased from an eBay seller in Hong Kong. Took about 8 days to arrive. The nice thing is these are encapsulated in clear silicone to make them waterproof and they have 3M adhesive on the back. The roll is about 15' long, but I only needed three 3' pieces for this project. The rest will find other uses.
I always mount an accessory socket in the back corner of my trucks. Makes it easy to connect a 12v compressor, vacuum or other 12v device when working away from the interior. This one is made by Bell and can be panel mounted for a clean look. Also has a rubber cover to keep the elements out. It cost $9.95 at Autozone.
I made this harness for the 3 light strips that are mounted to the bows from my cover. The connectors are Radio Shack items while the corrugated sheathing and anchors came from Advance Auto. This gives the harness a clean, factory look and allows quick disconnection for whenever I need to take off the cover and remove the bows to load something in the bed.
Close-up of a connector.
The plug to power everything is a standard cigarette lighter-type plug. I connected the socket to the running light of the left taillight assembly. I prefer this to having it be hot all the time so that anything plugged into it can't be left on inadvertently.
The lights off.
The lights on. You can't tell because there's a lot of ambient light, but in the dark they really light up the bed. Makes finding things back there at night a lot easier.
Gardenfan
Chetwynd, BC
Nice clean install there, and good idea on the acc plug in the bed.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
So every time you want to roll the cover up you have to unplug the lights?
Miami Son
Miami Son
Banned
Port St. Lucie, FL
Only if I need to remove the bows. The quick disconnects make that very easy, though. The main harness stays in place.
Good to see you here, Werm. Still have that beautiful blue truck, I see. ;)
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Oh I got it now, the bows are not apart of the tonneau, I thought they rolled up with it. Looks good
Yep this truck will be with me till it can no longer move and is not worth fixing it
quietpeen
2021 TRX
Hellcat
nice write up. Really think the accessory plug in the back is a cool idea
Miami Son
Miami Son
Banned
Port St. Lucie, FL
It definitely comes in handy. I have a really bright 12v light I keep under the back seat in the event of a flat at night. I've never needed it for myself, but it has come in handy for some friends and being able to plug it in the back rather than inside the cab is a real convenience.
