rangemaster728
I upgraded the basic instrument cluster in my 2020 Ram 1500 Tradesman to the 7” EVIC.
It looks impressive but in setting up the data displays for the corners I do not see outside air temp as an option.
I looked in the selector menus for all 4 corners just to be sure that selection might be limited to certain corners.
Outside temp displayed on my original 3” cluster...
Any ideas? I haven’t made any changes in AlfaOBD that would affect this data (changed settings to enable DRLs and global window down, that’s it).
Tnx!
UPDATE
After re-checking every menu in the 7” EVIC and confirming none of the choices for the displays were outside air temp I finally just decided to use the “reset to defaults” option in the display menu.
NOW the upper right hand display shows outside air temp as default.
I then programmed the other three ‘corners’ of data and the selectable onscreen gauges for the left side.
No idea why that option disappeared.
Tnx!
UPDATE
