Spark plug recommendations
Jamesq87
Alabama
Stock engine. Just noticed my mpg's seem lower and doing a tuneup soon. Wondering if anyone has had better luck with a certain plug compared to others.
2006 Ram 1500 SLT Megacab
5.7/auto/4wd
2" lift,33's,minor exhaust tweak. (For now)
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
NGK 5306's.... I loves my NGK's...over 308k on the motor and purrs like a kitten...well, maybe a pissed off wart hog.. :)
Marciel
Ngk or champion low heat range plug is best for the hemi. Don't buy anything fancy.
Sent from my SM-N910V using Tapatalk
Danno
Mid Atlantic
2016 Power Wagon
Stick with OEM which is NGK or Champion, do not use antiseize on the threads of NGK.
jljbtm
NGK in my Hemi's are just right
07MegaCabRam
Chandler, Arizona
6.7L CTD
Need LOW HEAT range. So it's very important to stick to a cooper plug. Factory at that time was Champion.
As mentioned above - everything else will perform worse.
At least you're doing research instead of just throwing plugs in. I wish they didn't even sell other plugs for engine at the parts store. But then again, when you say you need 16, they ask, two cars??
Jamesq87
Jamesq87
Alabama
This is my first dodge so I'll be honest, I was pretty confused myself. I'd never heard of 2 plugs per cylinder. I've always dealt with older chevy trucks with 1 plug per cylinder.
5.7/auto/4wd
Raadz
