Spark Plug Wire Access?
Brewer
Southern Oregon
Cummins 6.7
kinda a weird/silly question... is there an easily accessible sparkplug wire somewhere on the 5.7 hemi? i can't even see one.
like i said... a pretty silly need but i have a little hour meter for my generator i got on Amazon. you just wrap it's wire around a sparkplug wire a couple times and it reads/advances that way.
but id like to advance it first a few hours so it matches the hour usage on the gen. this could be accomplished by just driving around with it for a bit. i need an accessible sparkplug wire though.
thanks!!
thanks!!
Depending on how thick the wire is,you should be able to unbolt and lift out one of the front coil packs,then wrap your wire around the plug boot,run it out between the coil pack and valve cover.If you just need to drive around for a short period of time,you can probably get away with out even tightening the bolts back in on the coil pack until you're done.It's not like the coil pack is really going to go anywhere unless you decide to start jumping the truck while you're doing the drive around,lol
Raadz
