Speakers upgraded...now no sound
bud217
Wisconsin
I recently purchased a 2015 Ram 2500 with the non-alpine Uconnect 8.4 system. 6 speakers total. I pulled all the speakers out and put it my Kenwood Excelon speakers that I have had. I had them in my 2014 ram and took them out before I got rid of it. I used the connectors that are compatible with the factory connector so I didn't have to splice anything. When I went to turn the truck on I now have no sound from the drivers door or front driver's side tweeter. All other speakers work and I've tried adjusting the fade and balance which works as it should just no sound from the speakers I mentioned. Any thoughts or advice?? Thanks in advance.
Witch
Hemi 5.7 liter
Test the speakers independently, if good has to be the connectors
B
bud217
Wisconsin
Well I feel dumb now... The night I installed them I re-checked the door woofer and swapped it out with the original oem speaker and had nothing so I had it in my head it was a bigger electrical issue. Tonight I pulled the tweeters and checked them which one of them must have had a loose connection and been shutting down the signal to the driver's door and tweeter. So all is good now. I should've known to re-check all connections. Thanks again!
