speedometer quit
12vcummins59
Cummins 5.9
My speedometer randomly quit working as I was going down the road, wondering what could be the problem
toomanymopar
5.9 360 V8
Sensor or instrument cluster. I would do the sensor first as its much easier.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Like Dapepper said, try replacing the sensor on the transfer case first, make sure you get a part from a reputable store, or at least get one with a decent warrenty. When mine went out I went through three sensors until I found one that worked.
Before that you can try a cluster self test. Hold the trip/reset button on the cluster with the key off, then turn the key on but do not start the truck. When the Odometer flashes the word Check, you can release the button. Then all the guages will cycle in a test, that will quickly rule out an IC issue.
toomanymopar
5.9 360 V8
Thats a useful tip I never new about the cluster test.
joshhhh
