spyder-halo-led-projector-headlights
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
they will physically fit, but the output from HIDs in those lights is less than stellar........
Cheap halogen projectors + HIDs <> awesome output. :-|
R
Ramhergood
Is there any in the $300 range that would work well? Thanks
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
the best aftermarket ones are from Anzo....still not the "best", but.....on budget, they'll work!
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
These are what I am using: IPCW® CWS-422B2 - Dodge Ram 2006-2008 Black Halo Projector Headlights
When you install the HID bulbs you will have to make a spacer for the bulbs arc to be in the correct spot. I use a true Philips HID kit which required me to make a 1/2 inch spacer. Once you have the arc in the correct spot the output is great. Remember with HiD kits if you get a cheap one you will most likely buy another kit soon.
