Squeaky and annoyed
Jameson
Fort Benning, GA
Since I installed the bilstein a my truck squeaks like a fat lady's wheelchair. Checked swaybar and top strut but..all tight. I rock the truck in the drive and hear nothing. When I drove its constant with the road bumps, high pitched and drives me insane. any thought??
12TrueSport
San Diego, CA
2015 True Blue Pearl Sport
HEMI 5.7
In my past experience with this I have been able to hear it when I bounce the truck, like a bushing or something. Take some WD40 to your front bushings just in case to see if it goes away. I had to do that every few weeks to keep mine quiet.
Also check if you have tire rub anywere. Rubber to metal would be a squeak. Squeaks are so annoying.
Good luck finding it.
J
Jameson
Fort Benning, GA
No rubbing for me unless I'm locked out on hill in reverse..I'll check the bushings.
J
Jameson
Fort Benning, GA
Rocked the truck and its either upper BJ, strut itself, or The CV shaft..fuckkkkk
jake09
Could be the top shock bolt. Maybe not torqued enough..Have to take entire strut out though to check which sucks..but i have seen ppl complain about it
J
Jameson
Fort Benning, GA
How tight should it be? Anyone tell me how many threads they see above the bolt?
HolyRamBatman
Deep in the Heart of Texas
The thread count won't give you the torque. You will need a torque ratchet.
When I was younger I used the forearm torque but know I swear by the real thing.
Have you tried the wd40 thing. It should help you find the squeak.
J
Jameson
Fort Benning, GA
I sprayed and the noise was still there..its like nails on a freaking chalk board now.
TaterSalad
St. Louis, MO
HEMI 5.7 4x4
I just had mine installed last week & I have noticed a very slight squeak from time to time when I'm driving slow and have the windows down. Luckily it's so faint that I cant hear it with the windows up. Still annoys me that i know its squeaking though! On the other hand though, I did hear a louder "clunking" noise this morning when I hit a larger bump. Didn't sound good but haven't heard it again... Does yours ever do that?
CoalRegion08
I have the exact same problem! The front left squeaks when I go over a bump in the road. I've had my bilsteins on for about 2 months now and they squeaking just started 2 weeks ago. I rock my truck back and forth every day when I get home and I cannot pinpoint the squeak. It's driving me crazy.
J
Jameson
Fort Benning, GA
It is under warranty yes. But I know that once I installed the Bilsteins, this noise evolved. I cant wait to get my Suspension lift lol.
J
Jameson
Fort Benning, GA
Took that side apart and adjusted some **** now the squeak is gone..for now. Not sure why though Lol. But now my damn alignment is off again..fuuuuu
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
Just wondering if the noise is still gone after the fix?...
Ram725
Jackson TN/Houston Tx
2012 Ram 2500 Crew 4x4
6.7 Cummins HO
I could not stop laughing reading this thread only because I KNOW HOW YOU FEEL!
I have the Bilstein 5100 and RCX 6" and upfront, primarily left side there is a high pitched squeak every time I hit small bumps. I rock it and cant seem to find it. Drives me absolutely insane.
Hopefully one of us will find the cure. I plan on taking the whole front end apart here in a few weeks once I am moved into the house.
I will find this squeak.... :893Chainsaw-Smilie-
