Squeeky wheels get the...
Black Pearl
After complaining about these two piece 20" chrome wheels making noise like they are going to fall off, and getting nowhere, I finally took matters into my own hands and fixed them. Here's how:
1. Remove offending wheel & place on sawhorses or barrel, backside up.
2. Clean the area between the chrome cover and the aluminum wheel as best you can. A rag and 409 worked for me. Let thoroughly dry.
3. Fill the space between the wheel and the cover with silicone adhesive sealant. I used Permatex black in the small sqeeze tube, others may work as well. It comes with a long applicator tip. I cut the tip at an angle, large enough to lay about 1/4" wide bead. I put just enough in the gap to bridge between the wheel and cover. Do this on all 5 triangles.
4. Wipe off excess from chrome immediately with a rag and mild solvent. If it drys it's harder to get off.
5. I went one extra step, and put some adhesive between the wheel and the chrome on the front side, in a few spots at the outside of the wheel. Again, clean off excess immediately.
6. Let dry overnight before driving.
I have had mine repaired for about 2 mos. now, and the wheel has stayed nice and quiet.
HemiPower36
CA
2014 Ram 1500 Laramie 4x4 3.92 8-speed
Well.. Since there's no pictures.. This never happened.
If I can quote Forest Gump:
Having said that. Photos do REALLY help.
B
Black Pearl
Squeeky wheels
Believe what you want. It solved my problem. It aint rocket science.
BlownGP
Houston/Baton Rouge
I would like to know what the hell your talking about?? haha..
You talking about the fake plastic covers that come on the 20s?
pickupman66
Tennessee
ill venture to guess that is correct. sounds like his moved and made some wort of noise. im glad mine dont but kinda sorta wish mine were just the aluminums.
gville35
