Staggered tires on 4g
CRam
Anyone run staggered tires on a 4g? I've been back and forth on what I want to do with my truck but I was wondering how a 305/50r20 rear and a 275/55r20 front would work. Anyone running this successfully? Any pics?
moregrip
I'm going to be running a 305/50-20 on the rear and a 285/50-20 on the front, stock wheels all the way around. Going to be awesome!
C
CRam
As long as tires measure the same diameter the abs shouldn't be tripped.
moregrip
the tire diameters are slightly different but I don't believe it will be enough to throw a code, but if it does I will let you know for sure so you don't run into an issue.
