Stalling
RyanMac
Regina SK
I have a 2011 1500 5.7 124000 km with a CAI and CAT back. I have been experiencing a sputtering and stalling when coming to a stop. The stalling happens when the truck has been left in the cold over night (-20C).
This happens even if the truck was plugged in and warmed up for 10 -15 min, and persists until the the drive train warmed up (engine 90C, Oil 80C, Trans 30C+).
Shifting to neutral, no stalling, or lifting on the brake slightly keeps from staling too.
I have cleaned the throttle body, trans fluid in full. Plugs were changed at 100,000km
If the truck was in a heated garage (work) i have no issues at all no matter the temps.
After looking into this i am suspecting the lock up on the torque converter. Can this be tested?
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
Any codes thrown?
R
RyanMac
Regina SK
No codes. Added the Gas Line antifreeze last night, have to wait for the results.
There does not seem to be any issues if I coast to a stop (no brake).
Tried driving with tow/haul on, made no difference.
Starts fine and idles good.
huntergreen
Marine Corps Navy Badge
I would start looking for a vacuum leak.
R
RyanMac
Regina SK
Checked for vacuum leaks and did not find/detect any.
I had no issues today on my commute to work at -22C . After adding the Gas Line antifreeze. Fingers crossed that it was that easy.
500rider86
This maybe a dumb suggestion but have you looked at your maf sensor and throttle body? If there is a lot of oil on the maf and a good coating on the throttle body it could cause stalling. Maybe dumb but it’s a quick and easy check.
Never mind didn’t see it only happens at cold temps. :) This is what happend when you skim a post instead of reading it.
Steve58
