STANCE!! * yes some offset/backspacing questions*
farmhanddunc
1. What is the standard rim size and offset on the stock 17s
2. What is the max negative offset you can run on a x12 (or x10) wheel with a 33x12 (or 33x12.5) tire with a leveled truck.
I appreciate the help.
N1ck
Regina Sk
You can get away with a 20x12 -44 on 33x12.50x20 tire with a 2.5" level, search for a member here by the name of Patrick as he has this setup.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Stock 17's are 17x8 +25 offset.
As Nick said above, you can run a 12" wide with with a -44 offset (which is most common) and a 33.x12.5 tire on a leveled truck. You may need to trim a bit of plastic on the back of the inner fender to clear them near full lock but that would be about it.
F
farmhanddunc
thank you gentlemen! also anybody with a stock height/leveled stanced out truck feel free to post some pictures
usaf2006
North Carolina
My 06 rcsb is about 1" up in the front due to new strut assemblies. I'll post a pic in a bit.
usaf2006
North Carolina
Hey sorry its late, lost the thread for a while, and got busy with the beautiful weather. All I did was replace my strut assemblies. New springs and all.
