Steering Adjuster
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Think I already know the answer to this, but while under my truck changing oil this past weekend, I noticed that one of these nuts were loose. These act as kind of a locking nut around that sleeve & shouldn't be loose correct?
Another question... I am not a big emoji fan but where did they move them to when they went to the new forum platform?
DodgeDude99
Oak Lawn, Illinois
No they shouldn’t be loose. I am guessing it’s the nut on the left since the paint pen mark doesn’t line up?
7091ram
70 and 91 and 99 89 and 06 and 2014
383 and Cummins and 360 v6 5.7 hemi
You are correct they should not be loose they lock the adjustment in place. Sorry I can't answer your second question . I have been following your build on your 68 and you are doing a super job.
Sent from my SM-N910P using Tapatalk
Ratket
Arizona-
^^ my 2014 has the same issue from when it was new. Every couple of weeks I would climb under and check it. I’m a pretty stout guy, I wrenched on as hard as I could and it always rattled loose. Eventually I put a little lock tight on there and that solved it.
68PowerWagon
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
I do not actually have a 68 Power Wagon. LOL The pic in my profile I believe is a late 40's PW. And yes, I would love to have one of those! Why I put that as my user name I don't know. LOL 68 is the year I was born & I like Power Wagons... that's all I got :). Oddly enough, I really didn't care much for the 68 PW body style.
68PowerWagon
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Lock tight sounds like the route to go. Thanks
7091ram
Lol didn't see profile pic, at that time of the morning without my bifocal and 60 some years, I been following a cummins conversion on a 68 pw so I claim senile state of mind in my defense lol
Will Ram 2500
Kansas City, MO
Mine came loose 2 months after the alignment I had done when I leveled. My steering wheel started to be off center and it got worse real fast. I got under it and found the lock nuts were loose so I took it back to the 4x4 shop that did my level and they restraightened my steering wheel and it's been fine nearly 30k miles since.
68PowerWagon
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
So far the alignment has stayed in & the collar hasn't moved but I am going to do as mentioned above & put some lock tight or black rtv glue to keep it from vibrating loose.
