Steering leak
Dthenewf
Stephenville Newfoundland Canada
Recently purchased a 2013 ram 3500 dually to haul my 4 ton excavator and help with friends farm hauling hay. 250,000 on the 6.7 l Cummins.
A small leak has me puzzled around the power steering. Don’t think it transmission cooler looks like from the pump seal. Not too familiar with these trucks. Any help would be great. I can see the seal coming out from looking up from the bottom at the steering linkage.
1H22
Canada
1997 dodge ram 2500, 2015 ram 2500, 2018 ram 2500
5.9L 12valve Cummins, 6.7L cummins
pictures of the "seal coming out " would help. if its the seal on the steering box behind the pitman arm than make sure knock it back in before it dumps all your powersteering fluid out.
had that happen on a 2015 ram 2500, shimmed the seal against the pitman arm with 1/2in plywood to get home.
D
Dthenewf
Yeah forgot to take pics. The seal is just starting to expose itself. I was told today by a mopar owner to push seal back in and put 313 gasket seal around it
