Steering stabilizer
Dodger11
Does anyone know of any place that makes a steering stabilizer for a 2012 ram 1500 , I have a rough country 6 inch lift . I have had no luck any leads would be helpful
BOWERSFJ
Uniontown OH
Steering stabilizer on IFS truck ? You sure that’s even a thing ?
Dodger11
Dodger11
I’m 99.9 % sure it’s not lol But with the lift and the leveling kit putting it at 8.5 inches of lift and the 35” tires. Not to good with Michigan roads . So was hoping maybe a custom shop maybe able to fab one up if anyone knows of one
ram1500rsm
Trabuco Canyon, CA
Are you converting your IFS over to a front live axel ? otherwise i have no idea how you would use a steering stabilizer in your IFS.
Dodger11
Dodger11
No I’m not , yeah that’s been the answer iv been getting from a lot of people. And if someone did, it would probably be big $. Just thought I’d try seeing if anyone has heard of one or maybe suggestions to help with bump steer
BOWERSFJ
Uniontown OH
Sounds like you “stacked” levels and lifts, which from what I’ve read, is never a good idea ... I’m surprised you were able to get it aligned, and your CV’s aren’t at horrific angles
Dodger11
Dodger11
I have extended struts not the spacers so the leveling kit actually helped with the angle along ,with 1.5” bigger upper ball joint . I mean they are still on a bit of a angle but not as bad as they could be.
ram1500rsm
Trabuco Canyon, CA
Have you checked the basics like control arms bushings ,BJ's, worned out tie rods/bushings, wheel bearings, messed up alignment etc, etc ?
IcyAgitator
Montana
do you have a picture of your lift and level? CV? Just curious to see what it looks like
joshhhh
