Steering wheel/brake pedal vibration
zeddy
Burbank, Ca
Not the vibration you're thinkin of. Tires brakes are good. I get this vibration ,grinding feeling in the steering wheel and brake pedal when I'm stopped at a light or just parked with the engine on idling. I feel it more when the ac is on. It comes and goes. Very consistant. Any ideas?
zeddy
zeddy
Burbank, Ca
Anyone? I've been using my ac latey and feel the grinding when the brake pedal is depressed at a stop It's like when the condenser kicks on, there is this grinding vibrating through the brake pedal. Happens every 10-15 secs. Very irrating.
Ricks Ram
It's hard for someone to accurately help diagnose something that strange without actualy being there to feel it. It shows on your profile your truck is a 2015. It should still be under warranty. If the problem is that consistent I would take it to the dealer and have them inspect it under warranty. If not I honestly can think.of any reason the A/C coming on can make you have a grinding feeling in the brakes and steering wheel while stopped. Obviously something is resonating through the truck when the system is on.
RodRam
Ga.
Could be ac comp cycleing on and off it can effect idle
