Steering wheel controls work intermittantly
maitai11
Nevada
Kind of embarrassed...made a stupid mistake. 2014 SLT Quad 4x4 5.7 Hemi.
Installed headers and disconnected the steering column (at the pinch bolt). Somehow, it went out of phase, and when I reconnected I got (I later found out, that is) a code indicating that the wheel was out by 360 degrees. But prior to that, I started up and forced (like an idiot) the steering wheel to the right and broke the clockspring. I had another one on hand and replaced it...but now my steering controls work only intermittantly when the wheel is turned...but not in the neutral position.
So...is there another part I broke? FYI, the harness was replaced upon 2015 recall.
Guys? Any help would be greatly appreciated.
Embarassingly yours,
Maitai
chopperman1
2018 Rebel
5.7L HEMI
Bad clock spring, ie a dead spot in it. Not 100% sure on the RAM's clock spring but most other manufacturers have a set screw in it that gets removed once it is positioned.
Flip-er
Raleigh, N.C
2013 Big Horn 4x4
SECOND the clock spring
had same problem, sometime worked, others not.
when not horn wouldnt work either.
fix was a new master switch in steering wheel and clock spring
M
maitai11
Nevada
Thanks flipper!
I JUST checked my horn - no go. I see a circular part that I believe is integrated but removable - do I need the WHOLE clockspring? I'll look for part numbers. Thanks again.
Flip-er
Raleigh, N.C
2013 Big Horn 4x4
Cant answer that as dealer fixed mine.
