Dash controls not working
Thecarter73
Littleton CO.
Hello I’m new here but I’m at my wits end trying to figure out why the heated seats, heated steering wheel and 4x4 quit working. The trailer controls work and and I can turn on the seats with the touch screen?? All fuses are good and we have snow in the forecast tomorrow. Thank youIMG_4215.jpeg
tron67j
Maryland
Did you run for any diagnostic codes? Have you checked fuses to be sure they are not blown and are seated properly? Did you add or do anything before the problem started? Have you load-tested your battery to be sure it is holding amps properly? Last thing to do on this round is check your ground connections, clean and tighten them.
If all this is not an issue, you could also try disconnecting the battery for a out a half hour and then reconnect and go through 2-3 start/run/shutoff cycles of about a half hour of running/half hour turned off and see if things reset.
If none of this results in changes hopefully others have some ideas.
Good luck.
