stock 2" rake - going 2.1" bilsteins?
MrLaramie
Austin
I'm measuring a 2 - 2.2" rake (measured from ground to fender-well and also from top of tire to fender well). Actual measurements are in the 37.5" -> 39.7" range.
Is it safe for me to go 5100s at 2.1" and assume a nearly perfect level, hoping for a little settling.
Putting bilsteins on all 4 corners. I'm also putting the airbags in the back for when I'm dragging the bay boat, but that's mostly out of paranoia that i'll sag too much, even though my boat fully loaded is probably under 3k lbs.
Will post pics when all of this is done.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
I was. 5" high at 2.8. You should be about level going 2.1. This was me nose high before my rear spacer20180130_163621.jpg
R.L.K.
Bristol , Tn.
What year and milage are you now ?
shadowhawk
Southeast WI
Time for a swap :)
R.L.K.
Bristol , Tn.
i’m 2009 with 110k miles.
2.1" setting should do well for you Sir , your front coils have already settled in . Most of the settling is due to the coil spring itself and not the Bilsteins shock imo .
If you find the front high after some drive time , then just install a rear coil spacer ( simple & quick job )
Good luck !
M
MrLaramie
Austin
Good luck !
thx. this was the reassurance i was looking for.
shadowhawk
Southeast WI
haha. i just got this truck. long story but couldn’t pass up the price. hoping to get a few years out of it
Not swap the truck... swap the shocks!
