Stop start switch
hwyhound
western PA
Hi, just purchased a 2021 Ram 1500 Big Horn, night edition. I've noticed I have no switch indicator light verifying that I've deactivated the start stop sequence. The switch works and the dash info confirms it. I can see there is a clear tab on the switch for the light but its not functioning. The manual confirms a light should be present and all other indicator lights work properly. Is the manual wrong? should the light work? Looking for some info before heading to my dealer.
Thanks
NorthStar1
Rosenberg, TX
2020 Ram 1500 Big Horn/Lone Star 4x2 Crew
Hemi 5.7 eTorque
Yes, there should be a light under the switch that should work. Does it still shut down at a stop? Or does it keep running?
H
hwyhound
western PA
The switch functions as it should but there is no indicator light to verify it’s activated.
yakalong
KC
I seldom turn it off, but I think there is a light behind the switch. I'll check tomorrow to be sure.
NorthStar1
Rosenberg, TX
Hemi 5.7 eTorque
My light is directly under the switch.
Farmer Fran
Earth
2020 Limited Loaded - Sold
These are all Hybrid trucks right?
yakalong
KC
I checked mine out today, there is a light on the bottom right of the switch when I press the button to deactivate the start/stop.
H
hwyhound
western PA
Thank you, I stopped at my dealer today and they also confirmed the light. I have an appointment on Thursday and will report back.
NorthStar1
Rosenberg, TX
Hemi 5.7 eTorque
I just looked at the 2021 owners manual online...yes, there is no light by the switch any longer...it is on the instrument cluster. See page 186/187 of the owners manual which states:
Push the Stop/Start OFF switch (located on the switch bank). The light on the switch will illuminate. The “STOP/START OFF” message will appear in the instrument cluster display and the Autostop mode will be disabled.
Then it proceeds to indicate there is a light by the switch too:
TO MANUALLY TURN ON THE STOP START SYSTEM Push the Stop/Start OFF switch (located on the switch bank). The light on the switch will turn off.
H
hwyhound
western PA
Ok, just returned from my service visit. The tech has stated on my work order that he found a "Star Case" S2008000183 referring to the indicator. A software update will be available 1st quarter 2021. I guess there is also a HVAC control off button indicator non functioning also. I'm not familiar with the "star case" term but I'm hopeful for a resolution.
NorthStar1
Rosenberg, TX
Hemi 5.7 eTorque
IMHO, a "Star Case" is always a much better sign than a "cannot duplicate" staring you in the face on the service ticket as you drive away from the dealer. "Star Case" typically means they have identified the issue and a fix is pending.
Squeaks
Kentucky
2019 Billet Sliver Limited 4x4 Crew cab
HEMI e-Torque
Actually, on my Limited the "switch" itself doesn't light, there is a bar just below and to the right of the push button that turns on/off. On when start/stop is enabled, off when it is not. This is the same light setup for 4x setting, Hi, Low, Auto, etc. The vehicle is an eTorque Hemi.
H
hwyhound
western PA
Has anyone got the update to fix this issue? I've stopped at the dealer several times with no luck. I know the light is supposed to light because I've seen it on a 2020. The switch defiantly has the light it just doesn't activate.
H
hwyhound
western PA
Found this on another forum, hope it helps someone.
"Yes the programming change was applied to this issue. My light NOW illuminates. Description from my receipt listed below:
"3827 service bulletin 18-048-21 18-19-06-EB Module, Powertrain Control (PCM) Reprogram current part number 68502742AC to targeted part number 68502742AD"
grvlpt
milton, Fl.
My 2021 5.7 has a message: stop/start not ready. It is not working at all. Any ideas?
1Popeye
