Street Tire Suggestion
Hankrebel
Mississippi
Cummins 6.7
2016 2500 2WD with 18’
This is my first HD truck and it will need tires soon. I don’t off-road but tow a 36 foot camper.
I’m looking for something a little more aggressive than stock, but not an AT tire.
I’m toying with the idea of finding some used 20’ wheels.
6 months to a year, I plan on a Thuren 2’ level kit and possible some fender flares.
What do y’all suggest with this in mind?
G. Mcpherson
Yacolt, Wa.
2023 Ram 2500 CC SB Tradesman
18" wheels and Tires will give you a softer ride with more sidewall. Nitto, Cooper, Toyo all offer good tires in what your looking for. Check out Tire size .com. If you want to fill out your wheel wells 34 or 35" is a good choice. I have the 2" ThuPXL_20201008_183031357.jpg ren front coils and you would still have some rake if you keep the Rear stock coils.
MADDOG
Out Exploring Arizona
I agree with ^^^Mr. McPherson^^^ on 18's with a bit wider and taller tire.
I installed a 2" level spacer on my 2500 with some nice wheels and Nitto Terra Grappler 35x12.50R18 tires. The ride improved quite a bit with around 55psi cold in the tires vs. the stocker RSA hockey pucks that were on the truck.
Hiya @G. Mcpherson :)
Hankrebel
Hankrebel
Mississippi
Cummins 6.7
Will the 35x12.5x18 fit on the stock wheels?
I don’t like chrome so I would get some black wheels to accommodate the different tires.
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
I went with Nitto dura grapplers, they are a great road tire. Wear like iron so far on my dually.
Rick Ram-jet
Big Bear Lake Ca
2016 2500 4x4 CC / LB
6.4 L
Based on several previous posts from those who tow, Michelin makes a couple of highly rated street friendly LT tires (LTX or something like that) look up the their site for specific tires...
theviking
I would go with at least a 9" wide wheel.
Good luck trying to find a 9" wheel with the proper offset/backspacing. Method and maybe one or two other companies make wheels with close to stock spacing. Otherwise everything else I see advertised seems to stick out a mile.
Hankrebel
Hankrebel
Mississippi
Cummins 6.7
What is the correct offset/backspacing?
I’m not looking for the go kart look but don’t mind the tires sticking out a little bit.
theviking
theviking
FYI, one of the worst things about a wider wheel track (besides safety) is not being able to use automatic car washes anymore. Would drive me nuts.
G. Mcpherson
Yacolt, Wa.
You can find a wheel in 20" that is +18 to + 21. Either of these would stick out from the fender about 3/4 to 1". Backspace would be 5 1/2 to 5 3/4". There are a lot of Photos to look at how this would look . Use Google for pics.
Hankrebel
Hankrebel
Mississippi
Cummins 6.7
So would a wheel like this work?
0 offset seems like it would be just like stock?
BRAND Helo Series
STYLE HE904
DIAMETER 18
WIDTH 9.000
BOLT PATTERN 6x139.7
BOLT PATTERN IN INCHES 6x5.5
OFFSET 0
HUB BORE 106.25
BACKSPACING 5
theviking
BRAND Helo Series
STYLE HE904
DIAMETER 18
WIDTH 9.000
OFFSET 0
HUB BORE 106.25
BACKSPACING 5
FYI, you have the wrong bolt pattern listed there. But does look like they have the correct 8x6.5 bolt pattern available as well.
SeppW
Northern VA
Hemi 6.4L
When I had my Suburban K1500, I ran nothing but General HT and always had good performance from them. Ran on the stock 16 inch alloy wheels. Looked at Michelin LTs, but never got around to them b/c of price point.
quickster2
SE Michigan
2015 Ram Laramie 2500 4 X 4
6.4L
Michelin Defender LTX M/S LRE all the way. Great tire now on my 2nd vehicle with them. Stock 18" tire size is fine for towing.
