dchapma1957
- Joined
- Sep 16, 2024
- Posts
- 166
- Reaction score
- 286
- Location
- Lakeland Highlands, FL, USA
- Ram Year
- 2011
- Engine
- Hemi 5.7
Starting a new topic as the motor is all back together from the cam/liffters. First, let me say thanks to all the folks that comment and offer their insight. Greatly appreciated.
Engine will not start. Yesterday I thought it was not getting fuel and when I tested the external relay it was not getting 12 volts to the repay. OK, easy enough. This morning I repaired the 12 volt wire to the external relay, using a new one with a new inline fuse (which tests good). Still would not start. It sounds like it is sort of firing.
To eliminate that relay for sure I made a jumper and directly powered the fuel pump. Same result, it sounds like it wants to. I don't want to burn up the starter.
No CEL codes.
Things I know for sure.
I know for certain I got the cam/crank timing correct. I checked it 4 times, using the marks on the timing chain and gear/phaser. I even painted the tooth on the crank gear yellow so it would be easy to see, and I drew and arrow on the phaser pully where that notch mark is on that gear.
Phaser at 12 O-Clock and Crank dot at 6. And the timing chain links all lined up.
I went slowly putting in the pushrods and you can't get intake and exhaust swapped because they simply wouldn't fit. I made sure the ball was in the cup on each rocker using a mirror so I could clearly see it seated properly. And when I put them in I wiggled it so I could feel it slip into the lifter. I could see maybe missing one or two pushrods but the motor would till start and run crappy and generate misfire codes..
I double checked that all the sensors are connected securely. Cam position, etc - I accounted for every connector in the harness.
When I had the intake off most of the gas ran out of the fuel rails. How does all that air get purged. I know the pump puts pressure in the gas but what if air is trapped in the rails - there is no schrader valve to bleed them.
Outside of pulling the valve covers and hand cranking the motor while watcching each and every valve, I am open to suggestions.
I don't have any starting fluid spray here and will have to wait until this afternoon to get some.
Thoughts?
No CEL codes.
Thoughts?
I always blame the edibles or my ADHD ! It makes me fell better...
