sub stage installed
S
scotts2012ram
Guest
Guy thought i let some guys know the setup im running. Sadly i had to put my truck on the back burner for a bit but know im back at it. I install the dual 10 ported fox box see that some guy where having sealing problems. Being i planned to run high end big pressure subs i found some stuff we use at work. Its called dynatex brand clear rtv adhesive sealant used it to seal the bottoms then let dry for a week only because i had to work. Then started the install all the normal parts had to come out but seeing my alpine dvd has a brain box i had to mount under the center console and amps under front seats. im using a older memphis m class amp on 2 sundown e10s these subs have massive motors and are not to be taken lightly. For a sub that run 80 to 90 each the sound you get is crazy loud and low. Ive played every kind of music and have not found anything bad about them so if you cant see paying 200 each for subs like type r's look into these. Will try to get pictures up soon.
B-Shot
Sundown is top notch equipment and yes the the E series subs are the best bang for your buck for subs that get loud and sound good doing it IMO. I waiting on Jacob to get done with the SD-3 line of subs so I can run a pair of 10's sealed.
Etroze86
Grand Forks ND
Same reason we are running the IVX line from SKAR in my wife's car can't beat bang for buck.
S
scotts2012ram
Guest
Yea i looked at the sd's but wanted sa's but the dealer i talked to said they never fit. I got 2 e10s for 20 bucks knowing they had to be rebuilt po clipped them to death. I rebuilt them then dropped them in. Now i find out they will fit in the box o well these thing do a dam good job
