S
scotts2012ram
Guest
Guy thought i let some guys know the setup im running. Sadly i had to put my truck on the back burner for a bit but know im back at it. I install the dual 10 ported fox box see that some guy where having sealing problems. Being i planned to run high end big pressure subs i found some stuff we use at work. Its called dynatex brand clear rtv adhesive sealant used it to seal the bottoms then let dry for a week only because i had to work. Then started the install all the normal parts had to come out but seeing my alpine dvd has a brain box i had to mount under the center console and amps under front seats. im using a older memphis m class amp on 2 sundown e10s these subs have massive motors and are not to be taken lightly. For a sub that run 80 to 90 each the sound you get is crazy loud and low. Ive played every kind of music and have not found anything bad about them so if you cant see paying 200 each for subs like type r's look into these. Will try to get pictures up soon.
