Subs and other audio info!
01rammer1500
What i have collected is:
Pioneer deh-x6800bt head unit
2 kicker 10" 500w subs in boxes
I want to get an amp, new tweeters, and replace my 6x9s. Does anyone know what kind of wattage the infinity amps are putting out? Just want to knownif they are worth keeping or not...
Does anyone keep the factory amps? Or when doing an audio build, is it better to have an aftermarket 4 channel amp to power the door speakers?
Sent from my LG-D850 using Tapatalk
01rammer1500
I got my new stereo in and working. Its by far the best stereo that I've ever owned, along with the most functional!
Now I'm kinda stuck! I just ordered the AVITAL 4103 remote start/keyless entry system. So I'm about to be doing a ton of wiring. Should i just eliminate the factory amps and run my own since ill be running wires that way already?
I'm very new to subwoofers as well. Where are you all putting them in your truck?
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
If you have a single cab I used to put mine right behind the seats with the tray removed, I could fit 3 10s or 3 shallow 12s back there in a quad cab either on the seats or a low profile box under the seats.
Merc225hp
NA
truck
gas
In my 96 all my subs were on the floor, just forget u have a backseat. It all depends on your decks output for the speakers and or what amp u use to drive the speakers. This time around I will get a 4 channel amp for the speakers (doors & rear).
01rammer1500
I really am considering running an aftermarket amp. Im more concerned with music clarity at all volume levels, and good bass at low volume. But im clueless when it comes to what all i need to get the audio build done!
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
theres a surprising amount of space. just be creative. In my regular cab i have a 12 in a box behind each seat and the amp is under the middle seat. i could easily fit 3 12's or 4 10's behind the seat. i could get double that if i stacked them but i dont have enough money lol
Plop92
Southern Idaho
V10 8L
If you have the time and money I would get a 4 channel amp and up grade all your speakers. Dont worry about how kany watts keep and eye for the ohms out put
rammy98
5.9 magnum
Aftermarket is the way to go
If your on a budget theres some kicker cs components that are 6x9s online for $100. If I was u I would get a 6x9 > 6.5 speaker bracket Or have one made. infinity reference has a component set with tiny tweeters that will fit right where the factory ones go. And clarion has a mini amp for tight spaces. U can put it in the dash behind the stereo and it puts out I think 40 rms a speaker. For other budget amps wheather its 4 speakers or subs precision power is fairly cheap but still good.
