Sunroof seal, drive cables 2013
David Kirch
TAMPA
Can anyone provide insight around the replacement of the sunroof glass seal for a 2013?
Also, the cables to move the glass seem to be jammed. It was a working unit but was overflowing in the drain channel in the rear, thus dripping on headliner.
I am trying to install a new glass seal and now the glass is jammed "down" but will slide back easily. The glass will not go to the "up" or vent position. I have already dropped the entire sunroof frame to troubleshoot the situation.
any wisdom would really be appreciated.
thank you
D
David Kirch
TAMPA
thank you
does anyone know how to calibrate the closing of the sunroof? It is now moving under power but not fully closing.
thanks
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
Crickets
You are a braver man than most diving into your sunroof the way you have! I have no advice but keep us posted!
Kmiko
