Swapping 88 318 for 79 360
underdogrow
360 4bbl
I'm about to pull the 318 tbi and 904 transmission out of my 88 D-100. I picked up a 360 magnum and tf8 727 trans for 450.00. My biggest concern is the length of my driveshaft I'm hoping it will fit Right in. I'm leaving the factory 8 1/4 rear end for now despite its weaker components I am on a budget. Well the new motor and trans fit Right in? Am I over looking issues with bypassing the pcm?
Sent from my SCH-S968C using Tapatalk
HemiLonestar
Navy Badge Coast Guard
MD
They will bolt in, you could have issues bypassing the PCM, personally in an 88 I'd either go full EFI conversion or considering you're putting an older engine into a newer chassis (which is usually illegal with emissions laws) convert it to a carb. There are some pretty good aftermarket TBI kits that will work nicely. Your stock driveshaft will be a bit too long as the 904 and 727 are different lengths, however you should be able to find a stock replacement as the 727 was an optional transmission. I would've looked for a newer magnum engine (you said 360 magnum, but you said it's out of a '79, no such animal) and hooked it to an A518, which is basically a 727 with an OD unit on it.
U
underdogrow
360 4bbl
Thank you for clearing that up, I've been fighting the 88 tbi system for the better part of two months now. When I got it I didn't realize the extent of work a previous mechanic had put in to bypass those emissions solenoids. I started by replacing the in line pump they had ran, I'm guessing to bypass this system
. I'm assuming when I reinstalled the factory fuel pump (new) I was unknowingly back to square 1. This motor and transmission I've decided to put in is stock from a 79 3/4 T crew cab. Holley 4 barrell. Picked it up on craigslist for 450.
U
underdogrow
360 4bbl
I know I would have been better of with something more efficient but money is tight and I need my truck back on the road
U
underdogrow
360 4bbl
One more thing will a shift kit get me sonewhere in the ballpark of the efficiency of an A518
HemiLonestar
MD
No even close. That older automatic is a 3 speed, the 518 is a and overdrive trans. Shift kit will help it shift better, but that's it. If it's out of a 79 then it might not even have a lockup TC.
U
underdogrow
360 4bbl
That was a dumb question found out shortly after posting
U
underdogrow
360 4bbl
I've run into a few more questions. This 727 has a short tailshaft the entire length measures only 27 inches. From what I've researched it has a fixed yoke. Dies that
U
underdogrow
360 4bbl
Does that mean I need a two piece shaft? Also I'm worried about my transmission mount lining up. If it doesn't will I need a new crossmember or just the mount itself?
U
underdogrow
360 4bbl
By mount I mean the plate attaching kit to the crossmember
U
underdogrow
360 4bbl
My rookie is showing bad. Short tail shaft 727 slip yoke compatible? Two piece shaft?
Pocho808
