Swapping Out Transmission Fluid
Oklahoma
Is the recommendation to pull the pan and replace it as well as the filter? Or to do a simple drain and refill?
Does anyone have a link to the kit/fluid?
brian42
San Diego, CA
2019 5th Gen (Sold)
HEMI 5.7L
The filter is incorporated into the pan so you replace the whole thing. Here are a few of places that Google showed me:
As for the procedure it's more than a drain and fill. If you have transmission temperature in your EVIC then it becomes easier as you have all the "tools" you need to monitor for the procedure.
Good stuff to read here: https://**************/community/threads/transmission-oil.21275/
The forum doesn't like 5thgenrams(.com) apparently. Substitute than into the asterisks and you'll go to the transmission oil thread on the 5thgenrams forum with lots of good info that you're asking about.
rockyj69
