How much is Red Line up in Canada? It's a much better option than mixing any motor oil with Lubeguard.Yeah, we don’t get those kind of deals up here… $20/bottle…
You can get it at either of the local speed shops in Calgary for right around 20 bucks a quart with taxes,that's if it hasn't gone up in the last couple months.How much is Red Line up in Canada? It's a much better option than mixing any motor oil with Lubeguard.
Well, PUP uses thin GTL base oils. That's actually the difference between PUP and PP, as PP uses Group III and GTL. If I was limited to using Pennzoil, I'd rather use PP than PUP, because PUP is chock-full of VII, probably cheap VII nonetheless.You can get it at either of the local speed shops in Calgary for right around 20 bucks a quart with taxes,that's if it hasn't gone up in the last couple months.
You can get PUP on sale at Canadian Tires for $34.99 right now for a 5 litre jug,even with throwing two 10 oz bottles of Lubegard in with the PUP it's still alot cheaper then Redline is
5 litre jugs of Pennzoil Platinium is on sale for $31.99 right now at Candian Tire,lolWell, PUP uses thin GTL base oils. That's actually the difference between PUP and PP, as PP uses Group III and GTL. If I was limited to using Pennzoil, I'd rather use PP than PUP, because PUP is chock-full of VII, probably cheap VII nonetheless.
Lubegard is more effective if you use it with solid oil, as in not "as thin of a base oil" as PUP uses. Valvoline, Castrol, Mobil 1. Heck, I'd try it with Valvoline EP and just keep the OCI shorter. Valvoline uses thicker Group III base oils.
I'm saying this because Lubegard can only go so far, and it can't improve upon your base oil. And you shouldn't use more than 3 oz per quart of oil, otherwise, you will dilute the add pack of the oil.
Castrol EDGE EP is actually decent oil, much better than PUP. It's the same formulation used in Jaguar/Land Rover supercharged V8 engines. It has a decent density. Yes, it's Group III-based. But if a luxury brand uses it, it can be used safely in a HEMI.
I got Red Line 0W-20 at $146 per case of 12 quarts. I got two more cases for the Durango. The dealership said I can use Red Line as long as I use the correct viscosity.
That would be $24.84 in US dollars. Not bad, considering you're getting 5 liters versus 5 quarts. We had a sale here a while back, 5 quarts of PP for $19.99, at Walmart.5 litre jugs of Pennzoil Platinium is on sale for $31.99 right now at Candian Tire,lol
The last couple of times I’ve been into JB Powercenter their Redline oils shelf was fairly picked over, minimal product. Mopac, though, always seems to have stock. Most of their engine/gear oils were $22/qt at that time.You can get it at either of the local speed shops in Calgary for right around 20 bucks a quart with taxes,that's if it hasn't gone up in the last couple months.
Selling lubricants is a good business.The last couple of times I’ve been into JB Powercenter their Redline oils shelf was fairly picked over, minimal product. Mopac, though, always seems to have stock. Most of their engine/gear oils were $22/qt at that time.
I’ve yet to see pup in a wal-mart by me.Pennzoil Ultra Platinum (PUP) is back to $25.95 @ Wally World online.
I'm already stocked for other vehicles, along with RL 5W-30 for Hemi truck.
They don't stock much anymore. Order online, have it delivered.
In case someone new sees this, Corey is running 0w40 amsoil and it is keeping his tick away like redline 5w30.1700 miles and still quiet
