- Jan 17, 2016
- 14,050
- 24,363
- 14 Sport
- 5.7
I always thought propane was classed as a high octane fuel,with generally around a 130 rating,but with less btu's then gasolene,and that was why you wanted to up the static compression to get the most power from it.I used to hang around a couple propane powered drag cars,and they all ran at least 13:1 static compression ratio's with pumping cylinder pressures well over 220 psi.A bit off topic - propane is the most dangerous of all......extremely low octane rating (easier combusted than gasoline), with vapor pressure similar -40F/C.
Be careful members that use it for various things (bbq, heaters, etc.). We were very nervous at work using it in spark engines - esp. finding the knock point for spark advance timing. Blew a hole in a Cummins gasified C series engine.
My dad ran propane powered tractors back in the early/mid 70's,and at -40 they wouldn't start unless you warmed the tanks up above that temp,as it basically wouldn't boil in the tanks and turn from a liquid to a gas that would flow. From what i remember from the propane classes he made me take as a teenager,propane won't boil at -40 and stays as a liquid,it has to be above those temps to boil and create any tank pressure
