Tail light and driver side park lights out?
JUSTCALLMESPARKY
TEXAS
Hemi 5.7 Sport
So i have 2012 ram sport 1500 crew cab, my license plate light and both park light on driverside do not work. But when i push the brakes the brake light comes on(same light). I checjed fuses and all are good. I pulled the license plate lights off and connected to batteries (jerry riggedl and they came on....
Whats the deal? Any one else have this issue. If so what was done or what help can you provide.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Advice from a Old Fart non gear head :O A fuse can look good but still be bad! If you have a meter you can ring it out (A Ohm test) If you do not have a meter you should add one to your tool box, they run from cheap . Do you know what fuse controls the lights? If so change it with a new one a cheap quick fix, no meter needed :) If that still does not fix the issue try checking the wiring harness connections ! They may have come loose or got corroded and loose the connection from hot or ground ! If you have a meter you can test from the socket to frame ground
Do I make any sense or have I confuse the hell out of you lol.. I suck and explaining things
Good luck and please update, you may be able to help someone else later :)
Reticle918
